please try this as it seems your DTM is damaged
- deinstall DTM completly from the PC using the “apps” of Windows:
- ensure nothing from Hilscher is still installed (check for “DTM” and “hilscher” in the apps)
- delete the folder “SYCONNet” from C:\ProgramData
- Delete the folder “Hilscher GmbH” from C:\Program Files (x86)
- take a look at the Registry (“regedit”) if Hilscher got deleted within “Computer
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Hilscher GmbH”
→ “Device Library” and “DTMs” and “GenericSlaveDTM” should be gone - grant the user FULL Admin Rights
- Reinstall latest DTM from our homepage
→ This time the registry should contain Device library and DTMs: - If above visible entries are NOT here the installation failed (please note that the amount of “kryptic”
entries can vary but at least a few must be available) - Start AS and the errors should be gone (probably you have to delete the NetX card and reenter it
again)
