Timeout when downloading from SafeDesigner 5.24.2.1
Hi everyone, we have a problem when downloading from SafeDesigner where it will work once, but when we try a second time we get:
Adjusting comms timeout in SafeDesigner doesn’t help. The only fix is to power cycle the safe PLC
Logger doesn’t show anything helpful:
Anyone got any thoughts please?
Thanks, Brian
Does this happen when downloading via SafePLC dialog box and/or also via RemoteControl?
Which versions?
Hi Roman,
The SafePLC dialog box. I haven’t tried remote control
SafeDesgner 5.24.2.1
AR M4.93
VC V4.73.1
mapp View 5.24.8
mapp Safety 5.24.2
Just tried mapp View safety web interface and that also times out, but both work OK on smaller projects
Brian
Hi @BrianGrimshaw , what is status of your issue, can you update us and Help Us Keep the Community Organized?
Hi Jaroslav, yes this is still an issue
Are you using the latest hardware upgrade of the SafeLOGIC ?
You can chose the version in the Physical View in AS (compile + download after change!).
I think it should be V2.6.0.x
