Upgrade from SDL to SDL 4: Is it possible?
Hola a todos;
Tengo una instalación compuesta por APC910 conectada a un Panel 5AP5120.1505-000, vía SDL 3. En las últimas semanas tengo problemas de pérdida de imagen y el touchscreen tampoco funciona. He realizado cambio de cable y he intercambiado el Automation Panel con otra de mis líneas y el problema se mantiene en la línea inicial. He concluido que lo que podría estar defectuoso sería el transmisor SDL 3 (5AC901.LSD3-00); pero mi proveedor me indica que está descontinuado. Mi duda es; si cambio el transmisor a SDL4: ¿Existe un receptor SDL4 compatible con mi A. Panel?
¡Gracias por su ayuda! :slight_smile:
Hello everyone; I have an installation consisting of an APC910 connected to a Panel 5AP5120.1505-000 via SDL 3. In recent weeks, I have been experiencing issues with image loss and the touchscreen not functioning. I have replaced the cable and swapped the Automation Panel with one from another of my lines, yet the problem persists on the initial line. I have concluded that the SDL 3 transmitter (5AC901.LSD3-00) might be defective; however, my supplier informs me that it is discontinued. My question is: if I change the transmitter to SDL4, is there a compatible SDL4 receiver for my Automation Panel? Thank you for your assistance! :slight_smile:
Wilman
There is also an SDL4 receiver available for your screen:
SDL4 receiver
Good luck with the implementation!
Jan
Hi @wtacangas, it’s great that you are using Community. I just added a translation below your original question, so everyone can understand it on first view :slight_smile:
PS: Check our AI helper part 2. You can write your question in your native language and ask AI for translation. It works also very well but it is not mandatory, use the way you prefer :slight_smile:
