4pp420.1043-75, what AR and AS I can use for test
Updated by moderator:
Good morning, I need to perform a bench test with a 4pp420.1043-75 unit, but I can’t find the correct runtime for this equipment.
sorry I don’t understand the request, especially in direction of air conditioner.
Please describe more in detail to what you’re heading for, thanks.
preciso do AR pois não consigo criar o projeto pois não tem o runtime no meu automation Studio. 4.12
Okay, thanks for clarification.
The PP400 family was supported just up to AR 3.xy versions. Automation Studio 4, up to V 4.12, can be used.
Some AR3 versions are still available via Automation Studio → Tools → Upgrades.
Latest version available is I3.10, so select this version in the version dropdown
And select then PP400
And process with “Download Selected Upgrades” & installation.
After having it installed, you can use a PP420 hardware configuration.
If you’re using a evaluation version of AS4.12 and Tools → Upgrades is not available, you can download the upgrade for AR I3.10 here:
https://www.br-automation.com/en/downloads/software/automation-runtime/automation-studio-40/v40-ar-upgrade-i0310-pp400/
Hi Alex and others. In the community, you can ask questions using your native language and let AI translate them before publishing.
Check this article.
How to Write and Translate Questions Using AI
