X20 BM 11 Rev J0 vs G0
Hi Kind Guys’
What is the difference between the ‘JO’ and ‘G0’ versions of the X20 BM11? I mean, can we use the G0 version base module instead of the J0 version?
Thanks in Advance.
the revision number of a module documents changes done over the complete hardware lifecycyle, for example if components were changed.
If you have a login to the B&R homepage and are logged in, you can see the revision history.
I checked the difference between G0 and J0 - the changes in between should not have any effect, so in my opinion, yes you can use G0 instead of J0.
Best regards.
